Warranty / Maintenance Question
Old May 12, 2008 | 11:41 AM
CalgaryG's Avatar
Hi all,
I was considering changing my own air filter in my 2005 G35 C. I had two questions.
1) This is my first car, and I never had the option of auto shop in high school. How do I change the filter? Do you just have to unscrew some screws, pop the old filter out and the new one in? Is there a good DIY somewhere?
2) Warranty.... do I have to have this done by someone with receipts etc. for it to not void my warranty? Or would a receipt for buying a new filter be enough?
Thanks for the help!
Old May 12, 2008 | 11:58 AM
PoliPino's Avatar
1) Yes, all you need to do is open up the air cleaner and replace the filter. I thought it was held closed with clips, but I may be wrong. I'm not sure you would need a DIY guide for it. Just open, replace, close.
2) You shouldn't even need to keep any receipts. I guess it may be a good idea if Nissan really puts up a fight, but I've never kept any receipts and never had any issue getting warranty work done. Doing it yourself can't void your warranty, unless they could show that you did it so grossly wrong that you caused the malfunction.
Old May 12, 2008 | 01:03 PM
CalgaryFlowRide's Avatar
Where did you buy your air filter in Calgary? What was the price? I think I should replace mine as well?
Old May 12, 2008 | 01:42 PM
CalgaryG's Avatar
I haven't bought it yet.... but when I went to Mr. Lube for an oil change they offered to change my air filter for like $65 and that didn't seem right.... everythingg35 sells them for like $10. Hopefully they ship to Canada
Old May 12, 2008 | 02:23 PM
Texasscout's Avatar
There are four clips you must pop off. Then there is a 10mm bolt that should be removed on your right holding the back housing to the inside fender well. It's still not easy to remove and replace it, but you can squeez it in, I did.
here is a link to the shop manual section on the engine:
http://www.g35frenzy.com/downloads/2...anual/B/em.pdf
Look under "Air Cleaner and Air Duct" on page 15 of the .pdf file.
Old May 12, 2008 | 02:24 PM
breftayka's Avatar
You can get them at any automotive stores for under $20. All you do is open up the box on the drivers side by the headlight and switch out the filters...
derres
Aug 28, 2015 03:27 PM
Team STILLEN
Aug 10, 2015 08:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
