high pitch sound on start up
Old May 18, 2008 | 04:58 PM
g35cam's Avatar
The past couple of days my car will make a noise when starting it up... it will only sometimes do it, not every time i start it. Its a very high pitch noise that sounds like squealing of tires. It only last for about 15 seconds. What the hell is this noise? I checked the belts and made sure they were tight...
Old May 18, 2008 | 05:00 PM
elayman's Avatar
it's the devil and you are awakening him!
Old May 18, 2008 | 09:06 PM
g35cam's Avatar
**** you
Old May 18, 2008 | 09:21 PM
Blue Meanie's Avatar
Is it you making the squealing noise? maybe you should take the gay test, and see exactly how likely it is you will make squealy, girly noises.
Old May 19, 2008 | 01:04 AM
g35cam's Avatar
that was seriously the lamest **** ive ever heard, you need to attend some kind of school to help yourself.
Old May 19, 2008 | 01:08 AM
Well, ain't you a grumpy ******.
Old May 19, 2008 | 01:27 AM
EM3RGY's Avatar
belt needs tightening. easy fix.
Old May 19, 2008 | 05:06 AM
Nin's Avatar
Nin
loose belt...****ty tensioner...etc.
definitely something to do with your belts
Old May 19, 2008 | 12:32 PM
g35cam's Avatar
i checked the belts and made sure they were tight.
Old May 19, 2008 | 05:13 PM
SukaZenki's Avatar
What year is your ride? Have you tried spraying the belts with Belt Lubricant? Depends on how old your belts are now. It could be drying out. Just a guess.
Old May 19, 2008 | 05:38 PM
xvfasttrip's Avatar
Happened to me, just spray WD-40 in the belts-pulley bearings. I think it's one of the accs. pulley bearing that loose lubrication after heavy rain. Try to spray the WD-40 when the engine is running, and target the bearings. If it kills the sound, then use a longer lasting, water-proof lubrication similar to WD-40. WD-40 will only last a couple of rains.
Old May 19, 2008 | 05:39 PM
xvfasttrip's Avatar
Actually, spray freely to the belt area with WD-40. That's what I did at first.
Old May 19, 2008 | 05:42 PM
partyman66's Avatar
Belt lubricant... hahahhahaha.
Old May 26, 2008 | 03:07 AM
g35cam's Avatar
heres a vid of the sound it makes...
Old May 26, 2008 | 03:29 AM
Nin's Avatar
Nin
wow thats loud
unfortunately it's hard to tell because the sound quality is kind of sh!tty
almost sounds like a really bad vacuum leak but then it stops...no way it would be that bad though i'd imagine
