Help!!
Old May 21, 2008 | 05:58 PM
Preston's Avatar
Urgent question about G35 handling (shocks and springs)
I like to ask few questions regarding ’04 G35 coupe suspension.
I want to update shocks and springs on my G35 and I am not sure if Eibach pro-kit is suitable for my needs. Lately, my car feels very rough through bumps. I feel every small bump(s) on the road and it drives me crazy. Beacuse of this, I don’t even change lanes b/c I hate that eruption from running over plastic lane indicators. Furthermore, every time I hit corners, I feel excessive body roll. What is causing this problem? I didn’t modify anything on my car or drop my car in anyway. Everything on my car is OEM specification.
Pls advise what maybe the cause of this problem.
If I have to replace the springs, I dont want to drop it very low, maybe keep it at maximum 1.0 drop. After review, I notice that pro-kit has the least drop options. Do I still need to buy camber to use this springs? Should I replace my shocks as well? If yes, what type of shocks do I need to use with this kit. Pls help someone.
Thanks
Preston
Old May 22, 2008 | 09:12 AM
g35panama's Avatar
tokico d-shocks
Old May 22, 2008 | 11:53 AM
xx7sephiroth7xx's Avatar
G
your camber will change with even the lowest drop. with a 1" drop, you'll most likely need a camber kit since an alignment shop will probably not be able to bring your camber back into OEM specs.
or, you could just not buy a camber kit and buy tires more often, but that... less cost efficient :P
Old May 22, 2008 | 12:15 PM
Preston's Avatar
I see........ Honestly, I want to minimize any after market parts if possible. Another member suggested that I should use 350Z H-tech b/c this shocks only give 0.7 or less drop and I can avoid purchasing adj. camber, is that true? Can I use Tokico D-spec with factory spring? Pls advise.
Thanks in advance
Preston
