Help - installing torque damper on a RHD
Old Jun 1, 2008 | 08:34 AM
stingray1211's Avatar
I need some help to install a stillen torque damper.
Because i drive the JDM version ( RHD ) , i think they are alot more wires at the same location. I read through the stillen manual to install and seriously it is much harder than it sounds..
i finished the grounding wires and it was much easier than this job..
I took put side the steering fluid reservoir and the coolant tank and i saw the 3 bolts ( right above the bracket word, there are 3 bolts forming a triangle, pic onlys shows 1 and abit) and the grounding point for the TCC ( 2 bolts hoiling this down )
I am unable to get the the 3 bolts to install the bracket and when i trial fit the damper it looks like it will touch and rub against the gold metal hose and the rubber hosing under the bracket word.
anyone can help me? otherwise it looks like i need to go to a professional to get it done.. hopefully they can move the wires ..
Old Jun 1, 2008 | 08:50 AM
surfquikslver's Avatar
you need extensions for your socket wrench.
Old Jun 1, 2008 | 09:09 AM
that is not a problem.. the problem are the wires.. it doesn't look like there are that many in the LHD and the stillen manual.
Which means i got to re-locate at least 1 bulk of wire( the grounding bunch from the TCC) as they are secured with a plastic /tie-wrap *** insert into the body and there is really no way the bracket will fit there without the wire tubing touching it.
Plus i have doubts it will clear the gold metal tube which sits between the damper. ( this i cant confirm 100% till i can fit the bracket )
Old Jun 3, 2008 | 07:45 AM
ok. got it installed at a mechanic for $20 bucks.
There is definately more vibration in the pedals .. 1-2 gear shift is smoother.. torque wise.. cant really feel that it arrives faster..
Old Jun 3, 2008 | 08:38 AM
after you drive around more youll start to notice it more.
yosip1115
Aug 26, 2015 10:46 AM
Mattdi
Aug 23, 2015 11:27 PM
Ray Feta
Aug 13, 2015 11:40 PM
Team STILLEN
Aug 10, 2015 08:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
