Automatic Window Adjusting and Auto off headlights NOT WORKING
Old Jun 16, 2008 | 07:34 PM
rollingwriter's Avatar
As the title says, I took my 06 coupe to Whittier Tint Shop in SoCal this weekend and had the windows tinted and now my driver side door doesn't do the "automatic window adjusting" thing is used to... you know... when you open the door the window lowers an inch or so to clear the window frame and after you close the door it normally goes back up and seals nice and tight. Well now its always up and almost hits the body when I close the door. Needless to say I'm pissed with the shop but they are closed today and i need to know if I can reset it myself. Oh, also another thing I noticed is that my lights don't cut off on their own anymore after I turn off the car. WTF!! Any help would be much appreciated. Joe
Car is an 06 AT coupe with intelligent key sys
Old Jun 16, 2008 | 08:33 PM
EM3RGY's Avatar
you can try resetting the motor on the window. you'll have to pull off the door panel though.
Old Jun 16, 2008 | 09:15 PM
vjquan's Avatar
Check to door jamb switch - they probably taped it in or unscrewed it altogether to get the window to stay up when they tint.
Old Jun 17, 2008 | 03:18 PM
vjquan you're the man!!!!
That was the problem, these knuckle heads didnt screw the door jamb switch back in.. it was just set in there but not screwed in and apparently the screw provides the ground for the switch. THANK YOU VERY MUCH.
jimNC
Jul 25, 2015 05:47 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
apintojr
Jul 23, 2015 10:52 AM
attarday
Jul 15, 2015 04:03 PM
