Certificate of the maximum axle stability needed
Old Jul 8, 2008 | 02:02 PM
rx8wanki's Avatar
In germany we need to show every mod to a technical car agency before we can drive with it on the streets legally.
So I just installed some spacers on my G.20mm in Front an 25mm in the Back with my OEM 19" rims.It looks perfect to me ,theres no rubbing.
Now I wanted to check them by the car agency but the inspection authority need a certificate from Infiniti or Nissan wich confirmed the maximum axle stability.
So I have now an effective offset of 10 in the front and a offset of 8 in the back with my spacers installed.
Can someone help me out with some papers that proof the axle stability due to my offsets.
Old Jul 8, 2008 | 03:42 PM
Curt G's Avatar
Good luck with that. I don't know if any state in the US needs certification like it (CA doesn't). Really, it's not as much the axle strength as the strength of the wheel studs and/or bearings when you add spacers. I don't want to get you into trouble, but can you just remove the spacers to get inspected?
Oh, and props for trying to do it the right way.
Old Jul 8, 2008 | 04:55 PM
rx8wanki's Avatar
thanks for your answer.the problem in germany is that I need to inspect the spacers not the whole car at the moment.So if I dont do that and the police stops me to control my car and the see the spacers which are not controlled (with no papers) they will give me a fine of about 300dollars and the can shut my car in the worst case.
Ive just found H&R Papers for 350Z Spacers they proove the stability of the axle till a offset of +-0.So I only need some papers wich say that the G35 has the same axles as the 350Z.Maybe someone can help me out with that.
Old Jul 8, 2008 | 05:32 PM
shabarivas's Avatar
keep us updated...
Old Jul 8, 2008 | 08:48 PM
GTreeFive's Avatar
did you try emailing HR tech support for thsese docs?
Old Jul 9, 2008 | 03:55 AM
rx8wanki's Avatar
no i didnt but thats a good idea will call them.
Jusseth
Sep 13, 2020 12:25 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
