noise from trans and dif, i think
hey people, ok i got a used 05 g coupe 6 speed, this car is great other than this dang clicking sound in first second and sometimes 3rd gear when i give it some gas and get off the gas, it clicks like 1-2 times, click click. so anoying. does not sound good at all and the other is the loud *** chatter, i hurd its normal bu dam, when i turn my car off it chatters 10 times louder soo, its got 46 k, i got extended on it
help!
help!
From what I've been reading it's fairly normal... when you shut your car off it's apparently the throwout bearing noise. Easy 'fix' is to just hold the clutch in when you shut the car off... works for me. Still annoying but it hasn't seemed to affect my car any yet...
Roll your windows down and get into first gear going like 3-4 miles an hour then tap the gas, if you hear a click from the rear your talking about a rear axle grease problem. Its covered under warrently. I had the same thing and it was an easy fix for the dealer.
If you are talking about the noise coming from the engine i dont know then.
Hope this helps.
Hope this helps.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
