Help! CAR DIES ON WARM STARTUP!! :(
same thing happened to me when i would drop out of 6th gear the car would die and if i started it warm while running errands, same thing, low idle then die. this all happened after i installed my plenum spacer and had the ECU reflashed. i did the idle reset and it fixed the problem.
well, I had my battery unplugged for a couple hours since I replaced both of my ballasts. Now the problem is back, I'll need to try to reset again tomorrow! Im going to clean out the TB and MAF this weekend.
edit: I should mention, in the past my G has almost left me stranded and wouldn't fire up at all for several minutes or hard cranking.
edit2: I also had my battery checked, it was rated @ 410 crank amps
Originally Posted by gangster3.5
and why is that?
Hasanbaloch
Feb 29, 2024 08:45 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
