What would cause my headlight fuse to blow repeatedly?
Old Aug 21, 2008 | 01:31 AM
Red_G35's Avatar
Unhappy What would cause my headlight fuse to blow repeatedly?
Hello, have an 04 coupe with 06 projectors. Ive had these on for a while now.. 6+ months. No problems 'til this Monday.... so tonight I took the battery out and checked the fuse... 15A blown. Replaced it and tried it... POP! I haven't changed the bulb out yet, should I? Do you think its wiring? Whats the best way to go about tracking down a blown fuse?
Thanks for any and all advice
Old Aug 21, 2008 | 01:57 AM
gEE805's Avatar
somethings grounding itself
Old Aug 21, 2008 | 02:27 AM
Red_G35's Avatar
please elaborate...
I tried using a different light bulb, still pops the fuse!
Old Aug 21, 2008 | 10:27 AM
caper's Avatar
grounded as you have a Hot wire touching a ground...ground as in the chasis...
look for melted wires...where a a positve and neg have melted together
or a pinched wire......
or has it been raining? maybe wet connection?
Old Aug 21, 2008 | 12:02 PM
Red_G35's Avatar
ill look for that, thanks... it has been rainy lately.
Old Aug 21, 2008 | 12:37 PM
Calcvictim's Avatar
does the bulb light up at all or does it blow right away, I suggest getting a few spare fuses and disconnecting one side(ballast_bulb) and then the other, this will help you trace what side the short is occurring on.
My feeling is that the short is between the ballast and bulb somewhere.
Old Aug 21, 2008 | 02:44 PM
Red_G35's Avatar
I have tried that, I took the headlight out and turned the light on and the fuse does not blow. Once I connect it to the headlight it blows. So I know its between the headlight itself and the bulb. I even tried a spare headlight with the same ballast and different bulb and it still blows. I tried different bulbs so believe its between the igniter and the ballast. Is that possible? I've throughly looked at the headlight light and cant see any burned wires or moisture. Throughout my search Ive probably blown 7 fuses. This is really frustrating, does anyone know what else I should be looking for?
edit: short seems almost definitely coming from the passenger side. it has its own fuse. one for the drivers side and one for the passenger side. only the passenger side is blowing.
Old Aug 21, 2008 | 02:58 PM
badtziscool's Avatar
It does sound like something with either the ballast or the igniter. I would probably lean towards the ballast as that's the only component external to the headlight and could possibly have water leak into it.
You could take off the ballast (or at least unplug it from the wire harness) and see if it still blows the fuse.
Old Aug 21, 2008 | 03:36 PM
Red_G35's Avatar
I figured it out... its the ballast.
Thank you everybody for the help!!
Old Aug 21, 2008 | 03:37 PM
Red_G35's Avatar
Will these fit my car?
http://cgi.ebay.com/ebaymotors/pair-...mZ310075376829
Old Aug 21, 2008 | 04:14 PM
That G Gray's Avatar
Originally Posted by Red_G35
those are a bit different
Old Aug 21, 2008 | 07:22 PM
G35Enthused's Avatar
Yea get something with a bit more quality, check the dealer or Craigslist for a used pair.
lil beezy
Lights
Dec 23, 2015 05:25 PM
JLee301
Sep 25, 2015 08:46 PM
2014g35x
Sep 11, 2015 07:53 PM
