abs, vdc, slip all on after spc camber kit and tein flex install
Old Aug 26, 2008 | 03:23 PM
snou52's Avatar
so i installed my spc front and rear at the same time i put my tein flex coilovers on and now all my lights are on...abs, vdc, and slip. i tried unplugging the battery for 15mins and plugging back in to reset my ecu and it didnt get rid of the lights.
at first i installed the spc front's with the abs bracket provided but didn't install the hub spacer and i thought that was causing the problem but then i removed the abs bracket and just put it in the stock location and the lights are still on.
i haven't gotten an alignment yet and i just read that may fix this issue? i'm trying to get all the lights off first before i take it in for an alignment.
also there was a little rubber peice which seemed like a rubber boot to keep debris out from the abs sensor that was ripped off does that make any difference?
any help would be appreciated...i'm going to try to reset my ecu the way its listed in the DIY section tonight when i get home.
thanks
Old Aug 28, 2008 | 11:24 AM
snou52's Avatar
bump
Old Aug 28, 2008 | 11:59 AM
elrooko's Avatar
Is your brake fluid below the MAX line?
Old Aug 28, 2008 | 12:21 PM
snou52's Avatar
yes brake fluid is full....all lights are on
Old Aug 28, 2008 | 12:50 PM
redlude97's Avatar
its likely the front SPC kit, you need to realign your sensors
Old Aug 28, 2008 | 03:04 PM
specialist's Avatar
i never knew that how to you realign your sensors
Old Aug 29, 2008 | 11:55 AM
snou52's Avatar
hmmm i guess i'm going to need to take it in to infinity...i'm thinking the front sensor's need to be realigned as well....thanks for your input fellas.
watch out for the other guy
Old Aug 29, 2008 | 12:13 PM
Boston's Avatar
Have you tried the ABS sensor bracket with the hub spacer? I installed mine with both, had all lights come on 5 mins after the install. Turned off the car and restarted and all the lights have been off for 9 months.
Old Aug 29, 2008 | 12:19 PM
silver g's Avatar
That's weird...who did the install? Are you sure it was done correctly?
Old Aug 29, 2008 | 03:24 PM
trm3's Avatar
I hadthe same problem. Found out I used the wrong brackets. The left one was switched with the right one. Simple change and the lights were gone. I also had the spacers installed.
Old Aug 29, 2008 | 04:22 PM
npecora's Avatar
strange
i just took mine in to dealer for that problem
and they said my throttle chamber sensor was bad..
i pick it up today yah
Old Aug 29, 2008 | 05:16 PM
ajx215's Avatar
thanks
It could be your brake switch sensor. I just got mine fix last week. And that what the dealership told me. Warranty took care of it. My abs, slip, and vdc were all on when I step on the brake and cruise control set was blinking when I press the button.
Old Aug 29, 2008 | 06:28 PM
snou52's Avatar
i didn't install the hub spacer and i currently took off the provided abs bracket so it's sitting in there the stock way which should turn the lights back off right???
i wonder if i put the hub spacer and bracket back on if the lights will go off??? i'm planning on getting an alignment this weekend (still haven't done it yet) but maybe i'll throw the hub spacer and brackets on first, what do you guys think?
yeah i'm positive the install was done correctly...it was done by myself and my buddy who's a mechanic...we've double checked the install.
Old Aug 29, 2008 | 06:30 PM
snou52's Avatar
also, this is a dumb question i know, but i should be able to take it into nissan for them to check it out right?
Old Sep 5, 2008 | 10:37 PM
surfquikslver's Avatar
welcome to the club..mine have been on for months :/
