04 coupe veering right??
Old May 14, 2004 | 12:22 AM
yamar's Avatar
hey guys,
i have my g35 coupe for like a month now and i notice my car tends to veer to the right very quickly. i don't think it's an alignment problem since i haven't curbed anything. any of u guys have this problem? any comments or feedback is appreciated.
Old May 14, 2004 | 12:54 AM
blksnake's Avatar
Re: 04 coupe veering right??
Have your G checked. The dealer should cover it since you've only had your G for such a short time.
BLKSNAKE - '04 G35 Coupe
Check out my hidden sub! [img]/w3timages/icons/laugh.gif[/img]
Old May 14, 2004 | 02:08 AM
6mtInCharlotte's Avatar
My dealership didn't align my G correctly. Had to take it to a Nissan place to get the job done right. Half the price too.
Plus, the stock Pilot Sport tires are sh*t. Might be the prob.
Old May 14, 2004 | 07:08 AM
Speedoholic's Avatar
G (enie) FUNK ERA
Take is to the dealer.
There is a TSB for that.
Service Bulletin Num : 03028 Date of Bulletin: ?
Type: Coupe
Component: FRONT AXLE/SUSPENSION
Summary: Steering Drift to the Right
IF YOU CONFIRM: The vehicle has a tendency for a constant drift to the right on a straight, flat road at highway speeds. NOTE: A vehicle is said to drift, if The vehicle completes a lane change in less than 7 seconds and with no steering correctionfrom the driver and when driving at 60 mph and all four wheels must pass into the other lane during this time (7 seconds) and while driving on a crown-sloped road of less than 1 percent.
ACTIONS: Verify the incident drift as described above. Install the right front suspension compression rod from the Parts Information section of this bulletin.
04 6MTC DG/G/Prm/NAV/C.Crnrs/C.Br/A.ped/Polk/PIAA/Grnd.Kit/Rebadged/JWT Pop Charger/Z-Tube/Spl.Grds
Old May 14, 2004 | 09:31 AM
G35_Diva's Avatar
Yep I took mine back and referenced the TSB. My G was doing the same exact thing (right pull). The dealer replaced the compression rod first. However, they did NOT do an alignment when they changed the compression rod, so it still had a slight pull. I then took it back and they did an alignment with their new $30k high-tech alignment machine. You would think they would have done this the first time. I recommend you have them check the alignment after they replace the rod if that is your problem, so you don't have to make a 2nd trip back. Now my car drives perfectly straight. Yeah!!
Kim
04, DG coupe, Graphite, 5AT, Premium, Wheel & Tire, Splash Guards, Alum Pedals, Tint, Exact Mats
Old May 14, 2004 | 02:10 PM
yamar's Avatar
thanks for the feedback guys, will call dealership and get this fixed. peace
Old May 14, 2004 | 02:14 PM
XCELR8's Avatar
Stop trying to eat Quiznos while driving. That should solve it.
2003 BLK/BLK 6-spd Injen clear corners
Old May 14, 2004 | 02:51 PM
Bogler's Avatar
check first your tire pressure before bringing it to the dealer. the sensors will light up only if any tire is less than 25 or 26 i think. but uneven tire pressure up front, for ex. left=33, right=27, would cause your car to veer to to the right.
4020 P3MCG6T5I
Old May 14, 2004 | 03:23 PM
al503's Avatar
I agree with bogler but for a different reason. I caught my dealership in lie when they told me it was the tire pressure that was causing my sedan to pull. I had checked the tire pressures the day before thinking that was the problem. I took the G in and they said that it was the tire pressure. I thought that I could have made a mistake but when I picked the car up, it still had the pull. I got home and checked the pressures again. They were the same as the day before.
Old May 18, 2004 | 08:18 PM
yamar's Avatar
hey guys,
i just got my car back from metro infiniti and they supposedly fixed the veering to the right problem by replacing the compression rod and then doing an alignment, but after driving home from the dealership i notice the car is still doing the same thing, it's still veering to the right kinda quick. the guy there tells me all the g35 coupe drives like that. is this true? do your g veer to the right? thanks
Old May 18, 2004 | 08:21 PM
XIMER's Avatar
no,
today my car started veering left a little on my way to school. on my way back it started to veer left like crazy and found that it was flat. maybe you have a leak or something?
Old May 18, 2004 | 08:36 PM
G (enie) FUNK ERA
hey guys,
<hr></blockquote>
Not true! The tech is BSing you.
What kind of car is that that you need to hold the steering wheel turned slightly to the left in order to go straight? I would take it back and demand them to fix it.
Old May 18, 2004 | 09:43 PM
DED's Avatar
DED
I had the compression rod thing done. Helped a little.
Took it in again.
A little better. But wheel still needs to be cocked to the left to drive straight.
Driven on a level road with the wheel straight, it goes to the right.
With hands off, on a left tilted road it veers left.
Very very annoying. But I can't trust anyone to work on this car. Everytime I've taken it anywhere and let anyone else touch it, something gets F'ed Up.
I'll live with it..............
2004 G35C 6MT Black. I stare. And I am content.
Old May 18, 2004 | 10:30 PM
G35_Diva's Avatar
I guess I'm lucky that my dealer got that new high-tech alignment machine. In fact, the service manager suggested I waited for it to arrive and be installed before they did my alignment. (5-6 days) I am very glad I waited. I guess all dealers don't have this new $30k machine. That sucks...
Mine drives very straight now.
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Th611
Oct 27, 2015 03:48 PM
Kal Hamm
Jul 24, 2015 08:55 AM
