Lights help (about to order)
hey whats up, I am gonna order the lights for the clearance and the license plate but wanted a little help first. Are these the same lights, 168's, i know they will fit into the clearance but not sure about the license plate
Guest
Posts: n/a
Re: Lights help (about to order)
Yeah, 168 style bulbs (also known as W5W) are the ones for your rear license plate bulbs. But if you want those blue-output lights, make sure it is a very dark coat of blue, such as like the PIAA 168's otherwise the light just won't look blue at all. First I purchased a pair of Philips Blue Vision W5W bulbs that feature a light coat of blue, but when they were illuminated, the color of the lights was just typical yellowish color. But the PIAA's worked very well.
MrElussive
03 G35C 6MT
MrElussive
03 G35C 6MT
There are 2 168 wedge's for the license plate, 1 168 wedge for the trunk, 2 168's wedges for the clearence strips and 2 for the clear corners. The overhead map lights have 2 dome and the door illumination lights are also 2 "dome" lights.
I personally put PIAA Xtreme whites in the corners, clearence, trunk, maplight dome lights, door dome lights(located at bottom of the driver/passenger doors).
I put PIAA Super Plasma (which is a little bluer but still white) in the license plate lights.
I got my wedges and dome bulbs here:
http://www.drivewerks.com/catalog/sh...AWG-detail.htm
Here is Brian Kincaid's Xcel spreadsheet for all the G35's lighting and bulb specs:
http://www.geocities.com/lakerscentral/g35lights.xls
Here is a link to a previous thread on this topic:
https://g35driver.com/forums/showfla...&part=all&vc=1
Hope this helps....
docron1 aka joepaniolo
Hope this helps....
I just put in my PIAA H4 fogs/hi beams. The specs say HB3, which I assume is the same? Tho I thought HB4 was like H4.
Real pain to install blind, with the wheels on!! So now, above the xenon low beam there is another light; is that the clearance light??? Is that as much a pain to install?
Anyone have ballpark pricing on all these bulbs, and jdm side markers(ebay)???
Clearance lights are easy to install. Do a search for "clearance lights" or "lights" and you should find a DIY.
drivewerks.com has PIAA sets for around $15 which to me is pretty reasonable.
you can get CC's at everythingg35.com for close to $40 I think which is pretty cheap. some places are selling them for $60 which is too mcuh IMO.
