Slow leak...
Old Oct 9, 2008 | 12:09 PM
GRRRRR's Avatar
Slow leak...
Any recommendations of a product to use for a left rear tire that needs air every few days? Its a slow leaker....
Old Oct 9, 2008 | 12:49 PM
Xet's Avatar
Xet
i used some of that green goo colored stuff and it worked decently... but in retrospect i wouldnt do it again. my drivers side front and rear were leaking, i took them in last weekend and they found a nail and screw. 10 bucks to fix each at a good tire place and its a much better fix.
Old Oct 9, 2008 | 12:53 PM
uf20wop's Avatar
you probably have a screw in it, take a look
Old Oct 9, 2008 | 05:50 PM
GRRRRR's Avatar
Slime
Has anybody tried the Green Slime product?
Old Oct 9, 2008 | 06:23 PM
Mr.GEE's Avatar
20 Year Member
I would not try any of that sealant stuff. It may ruin your TPS sensors.
Old Oct 9, 2008 | 07:29 PM
Xet's Avatar
Xet
yes i used it and i wouldnt again. just take it in and get it fixed it takes all of 1 hour and like 5-10 bucks and is a real fix.
Old Oct 9, 2008 | 09:04 PM
G35JNKCV's Avatar
check the valve stem it might be lose.
Old Oct 10, 2008 | 02:40 PM
accordfreak's Avatar
get soap and water and spray all over the tire and valve stem.. U should see bubbles where the leak is coming from.
Old Oct 10, 2008 | 02:51 PM
Deezflip's Avatar
I've used it also...it seals it up but mannnnn, it causes your wheels to be off balanced. I've tried to use as little as possible, just enough to seal it but it still manages to be off balanced. It'll shake like crazy at 60mph...and trust me on this, you would rather have a slow leak than the insane vibrations from an off balance wheel.
It evens states on their website that it will affect wheel balance in the FAQ section which I failed to pay attention to.
chinee
Jun 10, 2024 07:48 PM
magnetism80
Feb 1, 2019 10:00 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
