wing question
Old Nov 22, 2008 | 11:50 AM
Ian_H's Avatar
wing question
Was looking through the forums and couldnt really find anything on this but is it possible to take the stock wing off your car, mine is cracked so I'm wodering what I should do. Any help is appreciated thanks
Old Nov 22, 2008 | 12:05 PM
LightsOut's Avatar
SIETESG
its only on with double sided tape.
Old Nov 22, 2008 | 12:09 PM
Calvin's Avatar
Overglorified Altima
There are a few bolts, too...
You need to take the trunk liner off to remove the nuts. Thereafter you'll want to use some GooGone or something of the like to help remove the double sided tape.
You'll want to replace it with another wing to cover up the holes...
Old Nov 22, 2008 | 12:22 PM
LightsOut's Avatar
SIETESG
thanks for the correction.
Old Nov 22, 2008 | 05:04 PM
Ian_H's Avatar
sweet thanks for the advice. While im witing for the wing can i just take the other one off and tape the holes or will that not work?
Old Nov 22, 2008 | 06:52 PM
EL-EE-ES's Avatar
you can do that, or go to a car store like pep boys and pick up some plugs. the double sided tape is hard as hell to get off.
Old Nov 22, 2008 | 07:08 PM
Ian_H's Avatar
ok gotcha. I used bug and tar, goo gone when i took my wing off my rsx so that should work again hopefully
thanks
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
