largest tire width on coupe front wheels
i have an 03 coupe. i searched everywhere but no info. i want to
install 265 35 20 or even 275's in the front. The rim is 9 inch. i dont know the offset. do they fit with out draggin on fender or when turning
thanks
thanks
Well if your car is not dropped then you should be able to put them on, but at the sametime you really need to find out your offset. I have my car lowered 1.2 in the front and 0.9 in the rear, and my offsets are +20 and +25, and that is considered agressive. I need to put a 5mm spacer in the rear to give it that little more agressive look. If I went with 20's I would still be in good shape, so if you don't have your car dropped then you are fine. In my honest opinion if you do drop your car. Go with an offset around +20 and +25, and add spacers if you want to get what you want.
Originally Posted by ngarcia1983
i dont have the car dropped, i would like to drop it later on; with 1in front and .9in rear. is that ok for 275's in front
i will take the rim to a shop to have the offset measured. ill will just go with the 265 in the front then. the rear tire looks to inserted in the fender and kinda ugly. so i will definitely need some 20mm im selling (1 1/4 in) if anyone wants them or trade for some stuff.
ENVautoDetailing.com
You can easily fit a 275 on a 9" wheel up front with a +20 offset, whether you're lowered or not.
Originally Posted by Gdup35sedan
+20/25 is NOT aggressive for an 8.5/9.5 setup... redlude97 had a 9.5 +5 with a 275 or 285 tire in the rear...
He is talking about 275 in the front, and with my car I would think 275 is too thick of a tire if I were to put it up on the front tire. Just wouldn't look right especially if you have a 20 inch rim!
It would look perfectly fine with a 275/30/20 up front.
-GP-
read my second statement. I clearly stated that he can easily fit a 275 up front on a 9" wheel with a +20 offset, i know what i'm talking about.
-GP-
-GP-
