Just got an 04 G35, Need help...
Old Dec 16, 2008 | 10:10 PM
SwanyJr's Avatar
Unhappy Just got an 04 G35, Need help...
I just got a G35 and about a week after I got it, I had a very rough night of driving. Everytime I'd get to an intersection and would put the car in neutral, it'd quit on me. Everytime I stopped that night, it would do that. Now, it hasn't quit like that night, but the tach says the idle is around 2-3 hundred rpms when it gets warmed up. Sometimes when I come off the gas and throw it into neutral it idles down and almost quits, but not quite. Oh yeah, and the day after that rough night, I changed the oil, put full synthetic in it, and put a set of NGK V-Power Sparkplugs in it too. I took it to a shop and he said he couldn't hear a vaccuum leak, but I have no freakin clue. and too make things even worse, when I pop the hood under my car, I get a small hint of a burning smell.......any help would be greatly appreciated. THANKS!!!!
Old Dec 16, 2008 | 10:24 PM
mateuszkedzier0's Avatar
Recal
Recall Date : Nov 2004
Potential Number Of Units Affected : 58,000
Summary:
On certain passenger vehicles, the circuit board for the crank position sensor may have an improper solder joint due to solder deformation caused by heat stress accelerated by the existence of flux residue during the soldering process .
Consequence:
This could cause the "Service Engine Soon" warning light to come on, create a no start condition, cause reduce engine power, or cause the engine to stop running without warning during vehicle operation, which could result in a crash
Old Dec 16, 2008 | 10:37 PM
SwanyJr's Avatar
very interesting, I guess I'll take it in tomarrow then. Any idea if that would be covered under warranty then? I sure hope so, it sounds expensive! lol
Old Dec 16, 2008 | 10:39 PM
yes , if the problem is the recal it will be cover under the warranty, good luck
Old Dec 16, 2008 | 10:46 PM
SwanyJr's Avatar
whew I'll check it out. Any idea why I'd get the hint of something burning when I lift my hood up. Oil looks good, coolant isn't low.....I have no clue.
Old Dec 16, 2008 | 11:49 PM
try cleaning ur throdle body...
Old Dec 17, 2008 | 12:06 AM
INFNTI's Avatar
Something burning like a smell or like actual smoke?
Old Dec 17, 2008 | 11:04 AM
SwanyJr's Avatar
Its really just a smell of something burning, no smoke or anything. I can't locate it. I was thinking about taking the car in and getting the full fuel system cleaned at the Valvoline down the block. Good idea?
Old Dec 29, 2008 | 06:22 PM
SwanyJr's Avatar
ALRIGHT! I finally fixed my problem. I took apart the throttle body and the upper plenum. I used brake cleaner and removed ALL carbon. I took the MAF sensor out from the z-tube and used MAF sensor cleaner and installed all parts again. My rough idle went from 300rpms to a constant 600rpms after cleaning! I strongly suggest inspecting your Throttle body for carbon/dirt build up! Finally....I think I solved my problem.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
