Fast idle and deep sound upon start how come?
Old Dec 21, 2008 | 04:07 PM
imRACERX's Avatar
for a couple days i have noticed specially on a cold start that the sound is more muffled and idles faster. no other problems are noted. anyone have any ideas? thanks John
Old Dec 21, 2008 | 04:20 PM
MikeYo's Avatar
your engine is cold....
Old Dec 21, 2008 | 04:22 PM
koksik86's Avatar
is this your first car?
Old Dec 21, 2008 | 04:50 PM
GreenGoblin's Avatar
The goblin resurrection
That is normal, it is a fast idle to warn the motor
Old Dec 21, 2008 | 05:44 PM
Beebo's Avatar
Its a normal cold start haha
Old Dec 21, 2008 | 08:47 PM
imRACERX's Avatar
no no, i bought it new in 2003 its an 2003.5 maybe what i meant to say is that the exhaust sounds diff upon a cold start. i know it idles high normally. anyway, it just sounds off and rough sounding. hard to describe. gonna get an oil change and have them plug it in and see whats going on. thanks
Old Dec 22, 2008 | 12:46 AM
Darkstar752's Avatar
Does the idle go down to normal after 5 mins?
Old Dec 22, 2008 | 01:34 AM
Dephstar's Avatar
mine does the same thing.
Old Dec 22, 2008 | 07:32 AM
OBG3506's Avatar
My exhaust sounds deeper on a cold start but quiets down after the warm up phase!
Old Dec 22, 2008 | 08:33 AM
I am not sure if you hearing something unusual but if you car is idle is raised due to the cold start then the exhaust note will be different
Old Dec 22, 2008 | 08:37 AM
GEE35FX's Avatar
The exhaust tone on my last two Gs sounded deeper on cold start-up.
This is normal due to the higher rpm and the car will also be running a bit richer on cold start-up.
Old Dec 22, 2008 | 11:24 AM
joe603's Avatar
It has to do with the variable intake/exhaust and engine timing via the ECU...it has a different program when the engine is cold. You will hear a louder intake sound too.
Old Dec 22, 2008 | 05:02 PM
imRACERX's Avatar
its deffinately sounding diffrent than it ever has. could reseting computer do anything?
Old Dec 23, 2008 | 10:08 AM
joe603's Avatar
I just put on a lightweight flywheel and a stage 4 clutch...She starts like an F1 car now!
Old Dec 30, 2008 | 04:25 PM
imRACERX's Avatar
well i found the culprit. I had an oil change today and as the guy was lifting the car, i noticed a huge tree branch wedged between the exhaust and the frame. I have no idea how it got there but it must have been about 2 inches in dia. and 3 to 4 feet long. im assuming the vibration upon start up was doing it. otherwise the oil change did it. John
