Need help with lights!!
Old Jun 9, 2004 | 10:20 AM
SFLG35's Avatar
FGC President
Re: Need help with lights!!
ive seen the mtecs in person and they are a very close match. prolly the closes out there. havent seen the catz though. as for the clearance talk to shader7 or trentacinque. i know russ has the mtecs but im not sure which ines he went with for clearance lights.
i personally went with teh piaa extreme white high / fog bulbs. and the piaa extreme white white leds for both my clear corners and the clearance strip. the leds are a pretty close match to the hids. the high / fogs are a little off but not that bad.
ill see if i cant find the old lights post for you.
Daniel
5ATC / DP / Willow / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights / Z - Tube / OEM Remote Window Up / VDC Memory
Old Jun 9, 2004 | 10:26 AM
SFLG35's Avatar
FGC President
here you go. Lights - The Final Answer. Thanks goes out to shader7 for all those comparisons.
Daniel
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
Jnm07
Sep 5, 2015 01:16 AM
