Alarm Light Removal.
I'm trying to change the small red bulb next to the clock. The blinking light that our alarm is hooked up to I guess. I saw a thread a while back about changing the light. I was wondering if anyone knows what size and wattage that light is and where I can find one?
Re: Alarm Light Removal.
It's a LED, so there is no wattage rating. Its an odd size also, Bigger then a 3mm, but smaller then a 5mm. Some people ream out the hole to squeeze a 5mm in, but I took a thick piece of black paper and gently poked a hole with a 3mm LED in it. I then used the paper as a bezel and you can't tell at all that the 3mm LED is a tad too small. Once you pop out the center housing you will see that the LED is soldered to a circuit board. Carefully remove it and replace it with you new LED. Good places to look for LEDs are Radioshack, or check out www.digikey.com.
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Kevin
AIM: KPiersonTec
Here's the link for the DIY for swapping out the Security LED.
I changed mine to the RadioShack Blue LED.
https://g35driver.com/forums/showfla...=5&part=3&vc=1
docron1 aka joe
docron1 aka joe
Micale757
Lighting
Apr 8, 2020 10:46 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Mick_L
Aug 25, 2015 04:27 PM
