G dies in neutral while coasting????
Old Apr 10, 2009 | 04:17 PM
redlude97's Avatar
you don't save gas coasting in neutral in our cars. Modern engine ECU's cut fuel when there is no throttle input. You actually waste more fuel by putting it in neutral because without the drivetrain connected to spin the engine, the ECU has to supply fuel to keep the car from dying.
Old Apr 10, 2009 | 08:14 PM
silver g's Avatar
This happened to me a few times awhile back...no biggie.
Old Apr 10, 2009 | 08:21 PM
Locksmith's Avatar
When my car died on me it turned out my filter was really loose and after screwing it on and double checking all the hose clamps it worked fine after.... have you tried to look at your intake?
Old Apr 11, 2009 | 11:22 PM
G35Vt's Avatar
I'd check all the intake connections...... when I added my K&N it idled up and down pretty bad, would go down to like 500rpm and gargle, but got better after a few weeks......
Old Apr 12, 2009 | 03:15 AM
jpnelson1978's Avatar
It's a stillen intake. I'm going to clean MAF tomorrow and check everyting. Today it died between downshifts when I put the clutch in. But wants I hit the gear I downshifted into it started back up. Kinds like when you jumpstart in the middle if the highway exit merge.
magnetism80
Feb 1, 2019 10:00 AM
Thebaws11
Nov 30, 2016 12:54 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Adon
Sep 22, 2015 03:56 PM
Since 1983
Sep 19, 2015 10:26 AM
