MT Coupe dies while coasting after WOT
So, I’ve encountered a problem with my 2003 6-speed G35 coupe.
When I hit WOT in 3rd or 4th gear and put the car into Neutral let it coast the RPM’s fall below idle and the car shuts off. Any ideas what may be causing this???
My G has Injen cold air intake, TiTek test pipes, HKS exhaust, PowerLab plenum spacer, and an Osiris custom dyno tune.
Thanks!
Thanks!
"Pop Charger or short ram intake (SRI). Mostly for the glorious sound it makes at high RPMs. Realistically, you are better off with a paper filter in the stock airbox for engine longevity. Did I mention the SRIs look nice, too? DO NOT get a long tube intake (Injen, Nismo R, etc.) unless you only drive in dry weather. They are snorkels that will suck up standing water and hydrolock your engine. The horsepower gain of a long tube versus the SRI is small and not really worth the risk. Note: the JWT Pop Charger may cause your engine to stall if you are coasting in neutral at high speed." http://350zmotorsports.wordpress.com...ning-the-350z/
Thanks for chiming in! I’d love to hear more input from other members.
i had that issue when i had my intake on my 06 6mt coupe..but when i got home i disconnected my negative battery cable over night and when i drove it didn't shut off.. .try it.. .
