clock light not working
Discussion about the 1st Generation V35 G35 Coupe
Jun 22, 2009 | 12:21 AM
randy021186
May 2009
i just took off the clock and saw that there was 2 mini bulbs, could both of them be blow or is there a fuse for it?
randy021186
Find all posts by randy021186
Jun 22, 2009 | 05:49 PM
pwebb
May 2009
if the fuse was out for the circuit the clock bulbs are on, a lot more things would be wrong.
get the bulbs.
pwebb
Find all posts by pwebb
TEMP/HVAC no longer working (radio works)
arora_g35
02:52 PM
(Slip light VDC light Off) keeps coming on
Mry
Mar 3, 2023
01:03 AM
Passenger side low beam light, side marker light, and seat warmer light not working.
Micale757
Lighting
10:46 AM
IPDM,BCM,Ignition and key, ECU
mike730
04:25 PM
Headlights problems
attarday
04:03 PM
Tags
03
clock
coupe
g35
light
working
Back to Subforum
View Next Unread
Headlight bulb change- high beam
03:09 AM
