370Z brakes on G35
Old Jun 29, 2009 | 02:15 PM
jzhu625's Avatar
370Z brakes on G35
Does anyone know the 370Z BBK will fit on G35? cause i know G37 BBK does fit on G35 with a brackets for front. rear are direct bolt on.
Old Jun 29, 2009 | 02:36 PM
GreenGoblin's Avatar
The goblin resurrection
It is the same caliper just says nissan, you will need the braket as well... Coz at czp can get you everything you need.
Old Jun 29, 2009 | 02:47 PM
jzhu625's Avatar
so pretty much i need the SAME brackets right? just making sure. what about the brake lines? when i order brake lines should i pick 350Z brake lines or G35 brake lines? planning to order a set of stoptech brake lines.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
ddietz97
Jul 26, 2015 06:16 PM
laksjd84
Jul 24, 2015 05:12 PM
mushu
Jul 15, 2015 03:55 PM
