HELP! New Tires... ABS Problem
Old Jul 14, 2009 | 03:00 PM
bocatrip's Avatar
Originally Posted by Shawn87
Hmm, whats the stock preferred tire...Bridgestone?
GON God only knows. I'm sure if the OEM tires were put on there should be no issues, but most of us are not going that route due to numerous reasons including preference and price.
Demonteverde's Avatar
Moderator
No lights are coming on. Just the ABS activates when slowing to low speeds. I took it apart last night the clean the sensor and mag strip and it didnt help... I guess i have to take it to the dealership. FML.
Are you getting a spring noise when slowly come to a stop? If so I had the same thing happened to me when I had my camber kit with spacers put on. The dealership had to really clean inside the hub (from the rear part where the sensor plugs into), the sensor, and move the sensor away from the hub a bit. They used their consult tool to check the readings of each sensor to determine the problem while they had me replicate the problem/drive around and brake to show them.
Old Jul 14, 2009 | 03:10 PM
Shawn87's Avatar
Ya I have a full camber kit. I have the sensor spacers in that come with the kit, as the owner before me didnt put them in and the sensor was rubbing. But we corrected that problem a long time ago. I really hate if I have to removed both front hubs. Its weird that this problem only occured after I got new tires though. Thanks for the tip, if the new tires dont work Ill get them to do that too.
Thebaws11
Jul 2, 2021 11:36 AM
Thebaws11
Nov 30, 2016 12:54 PM
G35xdriver04
Nov 7, 2015 08:31 PM
mattdg35
Sep 14, 2015 11:28 AM
