G35 Brake Pads
Old Aug 3, 2009 | 07:08 PM
kevinn's Avatar
G35 Brake Pads
Hello all, I have a 2007 6MT with 39k miles (mostly highway) and changed my brakes today for the first time. The odd thing was that the mechanic said I didn't need my front brake pads changed, but I needed to change my rear pads and resurface rotors.
Is it me or is that strange? His reasoning was that i have rear disc brakes that wear out faster than front. What did you guys think? Any feedback would be appreciated. Thanks!
Old Aug 3, 2009 | 09:17 PM
G35fromPA's Avatar
Generally speaking, and in my experience with my coupe, front brakes wear faster than the rears because they do most of the work under braking (60-70%), but with these cars, it's not unheard of to see the rear pads wear out a bit earlier. You wouldn't be the first.
Old Aug 7, 2009 | 02:24 PM
kevinn's Avatar
bump
Old Aug 7, 2009 | 03:46 PM
JZ39's Avatar
Unless Infiniti uses a different pad compound front to rear, I would think it nearly impossible that the rears would wear out first, as the fronts do most of the braking.
Old Aug 7, 2009 | 03:58 PM
elayman's Avatar
unless you were running ur ebrake for a long time i'd think the fronts would wear out faster as well
Old Jan 31, 2010 | 10:04 PM
Fongyd85's Avatar
are the brake pads for the 07 sedan and 07 coupe the same front and back?
Old Jan 31, 2010 | 11:31 PM
gary c's Avatar
Having been in the brake business, having the rear pads wear more than the fronts is strange. It is possible you drove around with your parking brake partially engaged. Normal pad wear would be the fronts, right front to be precise. My previous ride was a '92 300ZXTT, I got 118K miles out of the OE pads. The rear pads still had another 30K miles left on them but I changed them anyway....it's the right thing to do!
Gary
Old Jan 31, 2010 | 11:56 PM
jebus2006G35's Avatar
same her bro. i just replaced my back pads. with only 30k. my fronts are still 70% good
Old Feb 1, 2010 | 03:31 AM
SacG35's Avatar
oem
Old Feb 1, 2010 | 08:59 AM
GAU-8's Avatar
Gary
E-brake is a drum system completely unrelated to the rear disc system. FWIW I just replaced mine over a week ago and my fronts were fine but the rears were on the squealer. 29K miles on the car too.
Old Feb 1, 2010 | 09:57 AM
cmesidewayz's Avatar
It's normal for our cars to wear the rear pads faster than the front. infiniti designed our cars to use more rear braking power than front. It helps handling under braking. same reason for our cars to wear the rear tires quicker, most braking and acceleration is going towards them
Old Feb 1, 2010 | 06:18 PM
charlie66's Avatar
I have an 06' my rear brakes went before my fronts did.
Charlie
Old Feb 1, 2010 | 07:11 PM
GAU-8's Avatar
Could this possibly be because the car is rear wheel drive? (sense my sarcasm) An FWD car will wear the fronts faster than the rears. A RWD car will wear the rears out faster. I think that has less to do with braking than it does with being the driven wheels.
Old Feb 1, 2010 | 08:01 PM
G35fromPA's Avatar
No, our cars use more braking power in front. It's called brake bias, and our cars generally have about 65-75% front brake bias. If your car used more rear bias, you'd have frequent brake lockup under braking since the weight moves over the front wheels under braking. The result would be less stability and potential spins while braking and turning.
Old Feb 1, 2010 | 08:20 PM
herrschaft's Avatar
The front brakes do the majority of the braking as mentioned above, hence the larger calipers. I'm guessing the rears go faster because the pad is half the size than those on the front.
