Easy spacer question
Old Aug 8, 2009 | 04:46 AM
mcfly129's Avatar
I have an 05 g35 with 19in stock rims i was wondering if you guys thought 15mm front and 20mm back spacers would be flush with the fender? or maybe 20 20?
Old Aug 8, 2009 | 04:48 AM
Dranom's Avatar
some guys put 25mm on theirs all around
Old Aug 8, 2009 | 06:26 AM
aaalsadah's Avatar
25 mm all around FTW
Old Aug 8, 2009 | 10:37 AM
mcfly129's Avatar
any one have any pics of spacers on a lowerd / not lowerd car? 19in rims
Old Aug 8, 2009 | 02:28 PM
jookyshank's Avatar
I haz hugz to givez
Just finished my spacers 20mm/25mm...
Here you go
spacers on!
with
without
with
without
with
without
with
without
with
without
with
I know people have said 25mm all around, but on the OEM's I went with a bit thicker tire...245f 255r and these spacers are dang near perfect, I even rolled the back fender just a lil bit to eliminate some rubbing.
Hope this helps!
Old Aug 8, 2009 | 03:13 PM
blaccG35's Avatar
did you go 40 or 30 for the tires?
Old Aug 8, 2009 | 03:18 PM
jookyshank's Avatar
I haz hugz to givez
Bit odd,
245/35/19 Fr
255/40/19 R
Old Aug 8, 2009 | 04:19 PM
mcfly129's Avatar
I like the 20mm front 25mm back look. I wonder if I got the 25/25 spacers would the front rub if it was low on coilovers? Where did you buy them from?
Old Aug 8, 2009 | 05:38 PM
jookyshank's Avatar
I haz hugz to givez
I got mine from Henry
https://g35driver.com/forums/wheels-...available.html
Just looking at my set up, I would imagine rubbing would have been an issue in the front too but multiple folks here have said they didn't have any problems.
Also, once you drop the tires will tend to tuck due to the camber increase inherent to lowering, but I plan on combating as much as possible with full camber adjustment kits (probably from Statik too )
jsimonk
Dec 22, 2023 03:49 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
