Pass. seat stuck and I can't remove it.
Aug 21, 2009 | 08:17 AM
The passenger seat on my coupe won't move and it's all the way back. I thought of taking the seat out and working on it but I don't have access to the rear bolts because the seat is on top of them. I removed the motor ( which works once removed from the assembly ) by taking the front cover off and it still won't budge.
What can I do?
Reply 0
Aug 21, 2009 | 04:56 PM
anyone?
Reply 0
Aug 24, 2009 | 08:47 PM
I had the same issue but mine was stuck all the way forward. I was so pissed because I had lunch and purchase sweet tea ($1) which tipped over and got into the seat switch, which only went downhill from there because I couldn't remove the front bolts. Well anyways I have a friend who's a electrical engineer; he came over and had a great idea, tapping the motor connectors with another 12 volt source so the seat moves the other direction since the switch was out. After he figured -12v and +12v we were in business. Took apart the switch (it had sugar crust all over it) and washed everything and wipe the chip w/ rubbing alcohol assembled and voila! Works perfectly now. I called Grubbs Infiniti before the project, they quoted me 220 for the switch, I promise after looking at the small *** chip and the relay, it is definitely not worth that much. Also quoted me labor at another 300 dollars. Hopefully that helps
Reply 0
Aug 24, 2009 | 09:09 PM
Will the problem in my seat is not the motor nor the switch...it seems that the rails are stuck ( maybe a penny stuck or something ) and I can't get to it because the seat is so close to the floorand the rear seats are almost touching the front seat cause it's pushed so far back. I haven't messed with it again since I opened this topic but it I'll get at it soon.
Reply 0
