Hey I was wondering if anybody knew which type bulb the license plate light takes and how the installation works. Thanks. Also if u know any good sites to order from.
It's a 194 wedge bulb. To take off the bulbs just remove the license plate and unscrew the screws of the bulb housing, and it should be right there. When I took off the housings they where pretty dirty, so you should probably just clean them while your at it. You could check out vleds.com if you want to replace the bulbs with leds.
