Do I Need A New Transmission?
I just got off the phone with infinity and these are the prices they quoted me:
to change:
differential oil - $79.95
Transmission oil - $109.95
bleed brakes - $84.95
the infiniti rep said there is no option to change clutch fluid. is there another term they use so i can get a price?
thx!
to change:
thx!
A few important hints:
1) Always, Always, ALWAYS, remove your filler hole plug before removing the drain plug on the tranny or differential. The reason for this is so that you won't remove the drain plug first, drain all the fluid, and then find out that you can't get the filler plug off.... and you're SOL because you have no fluid in your tranny/diff now and can't drive it.
2) Buy a handheld cheapo fluid pump so that you can pump the fluid into the filler hole on your tranny/diff. It makes it a lot easier than trying to pour it in or snake long hoses up through your car to allow gravity to feed it in.
3) Don't overtorque your drain/filler hole plug bolts when putting them back in.
4) Remember to put the washer back on before putting the drain/filler plug bolts in.
5) Clean all debris from the drain plugs before putting them back in, and make sure the threads are perfectly clean.
to change:
thx!
to change:
thx!
Well it depends on which video you are looking at. For example, the automatic transmission service only applies to the automatics, however, the clutch fluid service video only applies to the MT models.
You saved me a lot money thanks..... The dealer wants to much money for a easy job that i can do myself......
i actually found two of your vids on youtube and used them to change the cabin filter and air filter 3 months ago! they were so accurate im gonna attempt the diff and clutch fluid also. thanks for the vids, i really appreciate them!
I took the videos off youtube a long time ago. They are all on infinitihelp.com but you can find them listed all on the Sedan section even though they apply to coupes & sedans. Check the link in my signature.
Same here. Fluids changed, still grinding above 4K RPM shifting to 3rd. I guess I will get the synchros changed. Any ballpark figure on how much it would cost? Also, does the new 3-piece synchros fit the old trans?
