G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Coupe V35 2003 - 07 (https://g35driver.com/forums/g35-coupe-v35-2003-07-14/)
-   -   I think i've got a major problem... (https://g35driver.com/forums/g35-coupe-v35-2003-07/314124-i-think-ive-got-major-problem.html)
Geezuz Nov 5, 2009 09:18 PM
I've had the manual back seat release not working for quite sometime (always meant to get it repaired but just never go around to it). This morning I went to pop the trunk with my FOB and nothing happened. I tried the interior release and noting happened. I tried the switch in the glove box and nothing happened.
How screwed am I now since I can't access the trunk through the back seat??
Any guidance would be greatly appriciated.
Thanks
Peter
gary c Nov 5, 2009 09:41 PM
The logical place to start would be with the fuses, beyond that I'd take your G to Nissan and have them fix both areas. Normally much less than going to Infiniti stealerships and I like Nissan mechanics better!
Gary
Geezuz Nov 5, 2009 09:46 PM
Thank Gary,
I did check the in cabin fuse panel and they seemed okay. I am not sure if there are any trunk related fuses under the hood but I will check this too.
Geezuz Nov 5, 2009 10:15 PM
Found my answer...
http://www.6mt.net/forum/g35-coupe/1...k-problem.html
Now to figure out root cause to why the trunk release will not work.
ilovez33 Nov 7, 2009 08:30 AM
I have an 06 and this happend to me the other day. I believe it was the latch on the trunk not hitting properly that caused it. Because as soon as I pushed down on the trunk lid it worked.
Titan23 Nov 7, 2009 10:06 AM
didn't have that happen yet but good to know that the answer is out there in case I need it
Bruin003 Nov 20, 2009 11:09 PM
thanks for the post
umair Nov 21, 2009 04:11 AM
for future reference... just dont fully lock the back seat :)
i do this with my other car as i have speakers in the trunk and just lay the seat back without locking it so when i blast the music i can lay the seats down :)
© 2026 MH Sub I, LLC dba Internet Brands
