Clutch issue advise please...
Old Nov 18, 2009 | 11:22 AM
sce1214's Avatar
Fairly new to the forum... whats up all!! Hopefully someone out there can shed some light on my issue...
I have a 2005 6MT coupe... had clutch pedal issues early summer... clutch pedal not returning... dealer said clutch problem and best to do throw out bearing under warranty and they will examine the clutch. Of course as you can imagine they said the clutch had alot of wear and suggested replacement. When they told me how much i almost dropped... now never did or does my clutch slip so i told them to clean it up and put it back together. Well i came home and looked at the forum and then went back to them and asked to repl slave cylinder to solve pedal issue... that worked and pedal still feels fine. However, it seems that since they cleaned out the clutch it is harder to put the shifter into gear. It seems like the clutch is engading ok but just hard to push into gear. i dont grind it or nothing but sometime it takes a little push to get it into gear
1 - Is this issue caused by bad clutch/flywheel?
2 - Am i doing any other damage other than to the clutch/flywheel by driving it like this?
3 - Recommendations for a moderate clutch/flywheel kit for moderate driver
I dont drive it often and not hard... not too hard anyway!
Thanks in advance!!
11bEMT
May 27, 2022 03:13 PM
zcherub
Aug 30, 2015 05:04 PM
NemesisGee
Aug 11, 2015 07:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
