Offset Question
Old Nov 29, 2009 | 08:56 PM
XmikeG35X's Avatar
Offset Question
I'm just curious how would 19x9 +20 / 19x10 +20 wheels fit on a stock g coupe? I'm thinking about buying some wheels I just want to know how they will fit.
Thanks
Also how do you think hyper black rims will look on a TB coupe?
Old Nov 29, 2009 | 09:20 PM
Drowe303's Avatar
They will sit almost flush with the fenders/ a little inwards. But it also depends on tire size. Your probable going with 245 fronts and 275 rears but you could fit 285 or even 295 on the rears. Since your at stock height I dont think you will need to roll your fenders.
Old Nov 29, 2009 | 09:23 PM
smokincoupe's Avatar
nah no fender rolling on +20 wheels im running 20s with 285s in the rear and lowered and it dont rub any.. if ur going for lucks i would go with 20s there cheaper than 19s in the long run even the tires are cheaper and it fills up the gap more..
Old Nov 29, 2009 | 09:37 PM
XmikeG35X's Avatar
I was planning on running a 245/275 set up. I have 20s now and I just want something a little bit smaller. That and I'm pretty sure the previous owner got the rims off ebay. Thats for the advise I just wanted to make sure that they would fit properly
Old Nov 29, 2009 | 10:17 PM
danches787's Avatar
I'm looking to put 20's on my coupe, will the offset be different on every wheel or is it standard? what should my offset be to be able to run a 295 in the rear?
Thanks
Old Nov 30, 2009 | 12:06 AM
offset wont be different on every wheel but 50/50 chance it can be different from front to rear... a 295 rear is kinda over doing it..
Old Nov 30, 2009 | 04:42 PM
LightsOut's Avatar
SIETESG
Thanks
for this question part... yes. you have more than enough room with a 275 or even 285 tire
Old Nov 30, 2009 | 04:45 PM
LightsOut's Avatar
SIETESG
Thanks
depends on wheel width.
10.5 295 tire 23 offset and above. could be more or less depending how much camber you want to run
Fire0nic3
Aug 31, 2015 03:18 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
