Headlights....and making them brighter!!!
Dec 1, 2009 | 02:22 PM
I have an 05 coupe and want to know what bulbs to get to make all the lights uniform in brightness. The bottom one is yeloowish and so is the bar running up the side. Im not experienced in car upgrades but thanks to you guys I'm starting to get it.
Thanks guys!!!!
Reply 0
Dec 1, 2009 | 05:12 PM
the bottom light which is your hbeam/foglight can just be switched out, the brightest thing you can do is put a plug and play HID in there with the same otuput as your stock HIDs, as for the side bar/clearance light, put an LED light in there.
i'm not entirely sure, but going over it in my head, it'll be difficult to match the colours exactly.
Reply 0
Dec 1, 2009 | 06:41 PM
Quote: the bottom light which is your hbeam/foglight can just be switched out, the brightest thing you can do is put a plug and play HID in there with the same otuput as your stock HIDs, as for the side bar/clearance light, put an LED light in there.
yeah, good luck matching the color. especially if you're extra picky like i am... so i gave up.
Reply 0
Dec 1, 2009 | 08:25 PM
you can match the colors if you buy 2 hid kits, one for the top and one for the bottom from the same brand and same color temperature, instead of trying to match the OEM hids. However if you have projector headlights the projector will give a different shade than the refector in the foglight.
Reply 0
