04 g35 clutch problem
Old Feb 13, 2010 | 11:31 AM
supraboi17's Avatar
hey guy well recently been have my clutch pedal getting stuck in a half way position, but if i lift it back up with my feet and pump a few times it would be fine and after few mins it went back to the same position after i press clutch in again and the clutch doesnt seem to be soft its pretty stiff, so im thinking it might be slave cylinder or the clutch cylinder just wanting to know if this have ever happen to anyone of you guys.
Thanks
Old Feb 13, 2010 | 12:16 PM
0MGHI2U's Avatar
you need a new slave and master clutch cylinder. it is covered under warranty.. if you still have warranty..
**also there is a HUGE THREAD ON THIS( USE SEARCH BUTTON MAN BEFORE U GET FLAMED ON)****
Old Feb 13, 2010 | 12:34 PM
same olg's Avatar
GThirtyFive4Me is right, even if you dont have a warranty left the parts are not that expensive hit up Rick@Riverside thats where i got my slave and master from
Old Feb 13, 2010 | 01:03 PM
supraboi17's Avatar
is there a wrench where i could get to remove the master clutch cylinder? cause it seems to be in a angle .
Old Feb 13, 2010 | 01:06 PM
Grownmansexy35's Avatar
stuck
i had the same problem on my silvia! easy fix!
Old Feb 13, 2010 | 01:14 PM
supraboi17's Avatar
yea i know its a easy fix but the clutch hardline on the master clutch is hard to reach
Old Feb 25, 2010 | 07:09 PM
supraboi17's Avatar
hey changed master clutch cylinder, slave cylinder, bleed it and try gravity bleeding it too still getting stuck half way, any other reason? clutch fork?? cause i try pushin clutch fork and it seems pretty hard not sure if it suppose to be like that on the vq
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
NemesisGee
Aug 11, 2015 07:10 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
laksjd84
Jul 24, 2015 05:12 PM
attarday
Jul 15, 2015 04:03 PM
