What Wheel Spacers Do I Need?
Old Mar 3, 2010 | 01:31 PM
Reggae420's Avatar
I want to push the wheels out about 4cm, any suggestions on what kind of wheel spacers to get? 5 bolt 114.3, what other information do I need to determine what kind of wheel spacers to get, sorry I'm new to this. Thanks alot.
Attached Thumbnails What Wheel Spacers Do I Need?-img_0785.jpg   What Wheel Spacers Do I Need?-img_0786.jpg   What Wheel Spacers Do I Need?-img_0787.jpg   What Wheel Spacers Do I Need?-img_0788.jpg
Old Mar 3, 2010 | 01:33 PM
Calvin's Avatar
Overglorified Altima
Check the back of your wheels to check if they are recessed enough to accept bolt on spacers. If not, then you will need to get the traditional spacers that require you to replace your existing studs with extended studs (usually included with name brand spacers).
Make sure they are hub centric.
Old Mar 3, 2010 | 02:31 PM
xXHotelCrazyXx's Avatar
you will need to roll your fenders first, then figure out what size you will need
Old Mar 3, 2010 | 02:53 PM
nghiars's Avatar
if you want to move it our 4cm than thats 40mm... a little too much for a spacer IMO.
Old Mar 3, 2010 | 02:54 PM
LordFappington's Avatar
He doesnt need a fender roll, hes not even dropped. Im guessing he wants it to sit flush.
4cm = 40mm, You need a wider wheel.
Old Mar 3, 2010 | 03:09 PM
Fender roll is recommended with spacers. I would do it OP unless you want the possibility of going over a pothole and crushing your fender or cutting your tire.
jsimonk
Dec 22, 2023 03:49 PM
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
