second gear issues
Old Mar 27, 2010 | 12:44 PM
imGdup's Avatar
second gear issues
My G won't go into second gear after I launch it hard and bring it to high rpm, it just refuses to go into second. It just misses and revs up, I read sokeone else had this problem, is this common? Or is this something wrong or broken? Thx fellas
Old Mar 27, 2010 | 04:03 PM
LiquidREVUP's Avatar
possible your synchros are bad... try changing the trans fluid and see if that helps
Old Mar 27, 2010 | 05:44 PM
imGdup's Avatar
also forgot to mention that my car can come out of first and go into neutral at slow speeds with no grinding and it does the same the thing if im in 6th, havent really happened in any other gears but then again i dont try changing gears with out clutch.this happened by accident.
Old Mar 30, 2010 | 12:48 AM
danielj's Avatar
From: Winnipeg, MB (Biggest/Coldest city in the world)
^^^your shifter can be moved in and out of gears at certain rpms, can't remember what its called, but when i drove a old pontiac sunfire and it was about to hit the junkyard i used to do it all the time. i don't think its actually that bad either as long as you do it perfectly, i don't reccomend doing it on a normal bases.
arora_g35
Apr 16, 2026 02:52 PM
11bEMT
May 27, 2022 03:13 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
thewarden
Aug 30, 2015 04:00 PM
Frostbite91
Aug 20, 2015 07:20 PM
