drive belt sqeaking
just replaced both belts and no noise after start up but the next morning its crazy loud squeal. my belts are tight and not loose.
any thought?
thanks
any thought?
thanks
Our belts are supposed to be set at a specific tension if not they'll make the noise you're describing. Pressing down on the belt it shouldn't move more than a 1/4" so you may not have them tight enough.
Gary
Gary
will check again
I wish i could. I don't have the tools to do that since i moved here from Mass. I might need to as i heard the squeak again. How i will manage i'm not sure. Went away on its own though.
that sounds like my car... not sure what tho and its intermittent as well.
Make sure you loosen the sholder bolt before you use the jack screw. Also, Adding grease wouldnt hurt. My did the same thing once i changed it and then I tightned it to the spec mentioned above and it went away...
