Door lock delete?
Old Apr 18, 2010 | 11:20 PM
code2424's Avatar
Door lock delete?
So I bought the driver side door lock delete from infinite riverside. I don't wanna do the lock delete so I just removed the cover from the metal part it came with. Thing is I can't get it to fit on my lock, the cover. Does it only fit if I remove the lock? I've tried everything it just doesn't go on there.
Old Apr 18, 2010 | 11:25 PM
Calvin's Avatar
Overglorified Altima
If you're talking about replacing the driver side escutcheon with the passenger side, then yes, it will fit without removing the actual lock. It fits just as the old one. It's been years since I've installed mine, wish I could offer you some advice other than it will fit.
Old Apr 18, 2010 | 11:33 PM
code2424's Avatar
I'm not actually replacing with the passenger one. My car was stolen long time and the lock was changed and there was no cover and i ordered the lock delete for the driver side with the escutcheon. I was trying to get it on there but the lock kind of sits all the way down so the cover cant go on there.
Old Apr 19, 2010 | 12:25 AM
gary c's Avatar
Post your question on the NoCal site, there's a bunch of very knowledgeable members in your area maybe they can give you the right answer....
Gary
Old Apr 26, 2010 | 07:52 PM
walshtj's Avatar
I think I am a bit confused by your question, are you just trying to cover up the actual silver door key locking mechanism? If so why? I have thought about the possibility of my keyless remote battery dying and being locked out, but good thing is that in the slim possibility it does when I am out, you can still remove the door lock delete with your key and then use the key to unlock the door the old-fashioned way.
G35-R
Nov 7, 2015 01:21 PM
TNRocker
Sep 21, 2015 08:36 AM
douglas555
Sep 10, 2015 04:48 PM
