2005 G35 Coupe Steering Problem
Old May 18, 2010 | 11:14 PM
Sonyboys77's Avatar
Ok, I have a 2005 G35 Coupe. One day the steering seemed to have an occasional sluggish feel to it a couple of times over a 2 or 3 month period. Then about 2-3 weeks ago it became constant like it's not getting any assist. I checked and fluid was full, no leaks anywhere. Took to Nissan shop cause Infiniti dealer is 2 hours away and Nissan shop recommended power steering pump, changed that with OEM new pump, same problem, so we put in new OEM rack, still same problem. Anyone have any ideas as to what's wrong? Someone told me to order new power steering fluid sensor but tired of throwing money away.
Old Sep 7, 2011 | 10:32 AM
lamont29's Avatar
I have a 04 and its doing the same thing!!!!
Old Sep 7, 2011 | 12:15 PM
smoovarrowhead's Avatar
did you check all fuses to the system and any related relays? Have them test the sensor. check codes to see if theres any failed sensor
Old Sep 7, 2011 | 01:38 PM
bythabay's Avatar
steering assist sensor ftw.. is it plugged in??
Old Sep 15, 2011 | 12:02 PM
gfanatic's Avatar
I have the same problem. Did you ever get this fixed?
Old Sep 15, 2011 | 08:09 PM
AuAltima3.5's Avatar
Whhhatt? This doesn't exist, does it?
Old Sep 16, 2011 | 03:52 AM
bythabay's Avatar
I think it's actually a pressure sensor, here is a reference that I found:
Old Sep 27, 2011 | 10:10 PM
sage3's Avatar
Hey bythabay I been having the same problem. I'm trying to figure out the location of that reference you posted. Please help, thanks!
Old Sep 27, 2011 | 10:39 PM
gfanatic's Avatar
Same here. Please help!
Old Sep 28, 2011 | 01:38 AM
bythabay's Avatar
I took that screen shot from the ps.pdf of the FSM. The title of the page is:
Hydraulic Line - Removal and Installation. You should be able to download the FSM somewhere, but if you can't find it, PM me and I can try to help you locate it.
Old Nov 7, 2011 | 02:09 PM
tekila2001's Avatar
I have the same issue. I discovered that it is most likely the steering angle sensor. Once you replace it your abs/vdc/slip lights will turn on. The dealership will have to reprogram the sensor. Good luck.
Old Nov 11, 2011 | 11:17 PM
lij1's Avatar
i got a similar problem, took it into the shop and they said my lowering kit has made it stiff...it feels stiffer yes but it shouldnt take me soo much effort to unwind the wheel and stuff. after they said the steering rack was sweating a bit but it shouldnt make such a huge problem, then i said i screw it they were chargin me by the hour. im thinkin it might b the pump
laksjd84
Feb 28, 2026 01:58 PM
mike730
Jan 12, 2018 04:25 PM
Blakelyg35
Aug 15, 2015 12:12 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
