engine rebuild ideas
Old May 21, 2010 | 07:23 AM
fatlip's Avatar
Ok so i might have an OC issue but havent confirmed yet. So that said im thinking of rebuilding the motor. If the cylinders are ok then ill stay with the factory size pistons. If not then bore it out and go over size, High compression either way since ima keep it NA.
Since im only rebuilding the block I figure ill need:
Pistons/rings
rod/main bearings
gasket set
Labor is gona be free except if i have to bore it out. How does that sound so far? Anything else i should add?
Old May 21, 2010 | 09:49 AM
charlie66's Avatar
let us know what the total would all be if u had to pay
Old May 22, 2010 | 01:38 AM
fatlip's Avatar
https://g35driver.com/forums/engine-...eco-mahle.html
Theres a link so u can get an idea of what some of the parts would cost. I was thinking of using the weisco high compression pistons. For sure though id be calling a good tuner shop to see what all i would need and the pros/cons etc... I think the cost of labor is what kills on most rebuilds. But my boys at the shop i go to are very very good at what they do so i trust them. Other than the required baerings and gaskets I might also throw in a JWT cam. I dont want the set up to be complicated. Simple and efficient.
Old May 22, 2010 | 01:54 AM
fatlip's Avatar
https://g35driver.com/forums/engine-...ages-more.html
Another set of weisco pistons in the engine vendor section.
Old May 22, 2010 | 05:38 PM
tEh d0ct0r's Avatar
Titan V8 swap?
Old May 22, 2010 | 05:57 PM
jibberjabbers's Avatar
VQ35HR swap...
mtlruss
Dec 20, 2015 01:51 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
Gookiecrunch
Aug 19, 2015 12:00 PM
slider_ua
Jul 29, 2015 04:17 PM
