weird intermittent problem
Old May 29, 2010 | 10:06 AM
g35winnipeg's Avatar
hey all i have aproblem thats been going on for a few weeks now.
my drivers side corner light (clear corner) sometimes misfunctions, what i mean is while i am in the car and i put the turn signal on to make a left turn sometimes it will blink very fast indicating a light is burned out..... i go outside my vehicle and my turn signal isn't lighting up so thats where the problem is, other times it works fine.....
i tried changing the bulb, no luck, i checked my fuses and there all good, i took out the bulb an checked for corrosion and dirt in the connectors and its fine and clean.....
like i said it is intermittent.... it will not work for 30 minutes then all the sudden it works fine??
anyone have any clues why this is happening????
the problem started when i installed my 06 projectors into my 03 coupe......
Old May 29, 2010 | 02:32 PM
nghiars's Avatar
sounds like something is loose. possibly wiring.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
mattdg35
Sep 14, 2015 11:28 AM
douglas555
Sep 10, 2015 04:48 PM
Jnm07
Sep 5, 2015 01:16 AM
