Swapping Headlights - NEED HELP ASAP
Old May 29, 2010 | 05:05 PM
felixsc300's Avatar
Hello all,
I finally got around to installing my projectors I bought last month. Now I have one issue: how do I remove the ballast from my 2003 to affix it on the '06+ projectors? I removed the ballast itself, but there's wiring wrapped in heatshielded-tubing, and idk how to deal with that. I have the ballast removed, but I don't see anything I could plug it into on the '06+.
Sorry for the ultra newb question, but I did a quick search which didn't yield anything and half of the front end of my car is disassembled and sitting on the driveway.
Thanks in advance.
Old May 29, 2010 | 05:59 PM
IrockAG35's Avatar
Ohio G Club moderator
theres a brown plug in the 06 hl that is prob tucked up in the ballast hole..reach around in there and pull the plug wire out a bit..then plug in your ballast to the new hl..make sure u also have the rubber ring that goes around the ballast or youll get moisture in ur new hl.
Old May 29, 2010 | 06:00 PM
IrockAG35's Avatar
the only reason the plug wouldnt be in there is if u bought the hls used and they didnt come with ignitors
Old May 29, 2010 | 09:16 PM
felixsc300's Avatar
Ah, got it, thanks. I had to 'fish' the wire into the lower headlight where the ballast is.
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
TeamNoSleep
Sep 13, 2015 07:40 PM
DG2Door
Sep 11, 2015 08:04 PM
