tire wear
Old Jun 2, 2010 | 05:28 PM
OGKushRob's Avatar
tire wear
so it appears that i have some bad and super early tire wear. the back passenger side tire is bald inside whereas the driver side rear still has some tread...umm...wtf. i heard this might be a problem but how can i combat this? and should i switch the rears so the other tire gets even wear? or do the normal front to back roatation for my tires? this isnt looking good. bald uneven wear in chicago weather is a NO GO!!
Old Jun 2, 2010 | 05:44 PM
Deepdiver's Avatar
your camber is prolly out of spec.
Old Jun 2, 2010 | 05:46 PM
OGKushRob's Avatar
how would i fix that? or adjust it?
jibberjabbers's Avatar
Check your compression rod/bushing. Worn bushing can throw your toe out of spec.
Infinti has issued a new "revised" compression rod. Take it to an alignment shop and have then take a look. Might as well get an alignment to see if it within spec also.
Both G35 and 350z have horrible suspension. Nissan issued a TSB on the 350z suspension.
Infiniti is still dragging their feet.
obender66
18 Inch
Mar 13, 2016 12:20 PM
Depravity
19 Inch
55
Oct 16, 2015 01:36 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
INVADER_6MT
Sep 1, 2015 10:19 PM
smokey2
Aug 14, 2015 03:07 PM
