Windshied wiper fluid not coming out...
Old Jun 17, 2010 | 11:30 PM
TigerKneeCrush's Avatar
what could be the problem?
Old Jun 18, 2010 | 12:10 AM
walshtj's Avatar
Does it have any liquid in it?
Old Jun 18, 2010 | 12:21 AM
yeah. i filled it up all the way. i think when the airbag guy came, he messed something up in the dash or something
Old Jun 18, 2010 | 12:36 AM
nighthawk06's Avatar
I remember someone told me once do not fill the windshield wiper with 100% water because if you don't use the fluid for a while, the water will turn into the white thingy (I do not know the same for it) and could make the hose stuck.
Old Jun 18, 2010 | 01:02 AM
muellerG21's Avatar
check and make sure hoses are connected to the sprayers. pop off the hood trim piece and check hoses for leaks or breaks
Old Jun 18, 2010 | 01:57 AM
Tabris's Avatar
When I bought the car my washers would not spray (even after making sure they were topped up with fluid).
I took it to Infiniti, and it turns out that the tube that carries the fluid from the reservoir to the wiper arms had a hole in it. The hole was caused by friction (the tube rubbing against a part inside the car), the friction could have been happening over months or years though. Can't say for sure.
And that 3 minute diagnosis, and $0.20 part (spliced the tube), I left Infiniti with a $120.00 bill.
Also, If possible: Pop open your hood, have someone else turn on the wiper spray, and listen for the wiper motor (located on the passenger side front of the car). At least you could tell if your motor is toast or not.
Old Jun 18, 2010 | 02:10 AM
G35_REDLINE's Avatar
**** on it
Old Jun 18, 2010 | 04:33 AM
VictoriousG's Avatar
^ wtf lmao
Old Jun 18, 2010 | 04:51 AM
Originally Posted by G35_REDLINE
**** on it
lets have sex
Old Jun 18, 2010 | 04:59 AM
^ Umm k this is getting awkvard (in Bruno accent) lol
Old Jun 22, 2010 | 06:20 PM
so the guy that did my airbags is coming tomorrow morning to check out the problem. i hope he fixes it cuz he lost everything in my glove compartment; registration, insurance, etc
Old Jun 22, 2010 | 09:20 PM
junCakes's Avatar
lol. ask him.
Old Jun 23, 2010 | 12:26 PM
walshtj's Avatar
He lost everything??
Old Jun 23, 2010 | 03:51 PM
G35Lopez's Avatar
There is a small valve that connects two pieces of hose. You can find the little valve behind your battery. A buddy of mine had this problem and it turned out that the little valve was clogged. The purpose of the valve is to hold pressure in the hose.
-That's R&D for your money
Old Jun 23, 2010 | 05:48 PM
So the airbag guy found a problem. There is a blown fuse
