Quote:
not with my car right now so the best I can do is old pics that kinda show how they sit.Originally Posted by DT35G
Xet - would you mind posting up a pic? I would like to see the car with 25mm all the way around
These first two are from when I was on z-htechs (25mm spacers all around for reference)
These two are on my coilovers (still with 25mm spacers all around)
Hope that at least gives you an idea. Personally if I didn't drop my car so much I would have been happier with 25mm fronts/30mm rears but you will still be much happier with just 25mm all around.
Also my rear tires are 255/40/19, a bit sized up from oem as well.
^ what would you say your drop is about Vs. stock? 2inchs or so? (im just trying to get a reference for how much i want to lower mine, your drop with the spacers look great btw)
Sorry inda626 I wouldnt know that but im sure all you would need to do is just match the bolt at a local hardware store if anything...
and thank you for the response O HELLA...I knew I read that somewhere before but its always nice to hear someone else confirm it =)
looks great, im thinking 30 in the rear now and 25 in the front. how much is your drop?
ˆExactly what I was thinking 25mm front and 30mm in the a$$
ha
ha
does putting these spacers jeopardize ANYTHING? Meaning, the wheels were designed to sit up against the factory hub, so under heavy driving, do the spacers make the vehicle less safe? I understand the logic behind a wider stance, lower center of gravity type thing, not what im talking about.
Hey guys, i no im coming in mad late. I like those pics-looks perfect. I have exactly the same thing, 03 g35 dropped on eibach pro streey nd tokico d-spec shocks. I wanted to put spacer but i also wanted to put 265 and maybe even 275 in the back. (245 in the front) Do you think il have to roll my fenders or no?
Aliright I just picked up two sets from Henry (Mr.Wong @ STATIK) 25mm for the fronts and 30mm for the back...I will post up before and after install pics for more eyecandy visuals
Quote:
pics?????Originally Posted by cerberuslucid
aliright i just picked up two sets from henry (mr.wong @ statik) 25mm for the fronts and 30mm for the back...i will post up before and after install pics for more eyecandy visuals
I will be doing the install today at my friends garage today 25mm front & 30mm rear.
I will post the photos tonight...
dukehotty
close
- Join DateFeb 2010
- LocationSanta Barbara
iTrader Positive Feedback100
iTrader Feedback Score(14)
Liked:375 Times in 296 Posts
Hi. Somebody posted a good DIY for Ichiba V2 spacers. He has before and after pics. He used 25mm and they looked good. I went to craigslist and somebody was selling some Ichiba V2 25mm. He said he had them on for one day but has to sell them because of rubbing. So it sounds like we will have to get our fenders rolled.
Quote:
Also, ive seen pictures with spacers, but anyone who could post one here with 25mm all around I would appreciate it.
One more thing, if I drop it on Teins will they be out too far with 25mm and will I need my fenders rolled?
Thanks people!
I have stock OEM rays and want to pull them out a bit. I was thinking of going with the 25mm Spacers. How long of lug bolts am I gonna need. Wheres the most affordable place to get this stuff without buying sh*t. Also, ive seen pictures with spacers, but anyone who could post one here with 25mm all around I would appreciate it.
Thanks people!
Alright here we go...an 06' mt on OEM19"s with 25mm IchibaV2 in the front and 30mm IchibaV2 in the rear...
