Shell V-Power
Old Oct 1, 2004 | 10:12 PM
ARH_twilightblue's Avatar
Shell V-Power
This might be a dumb question but I've been using only V-Power in my G and I'm wondering if it's ok to use such a high octane gas (93) in a new engine? The car runs great on it though
'04.5 TwilightBlue Coupe [AT5]//Willow Leather//Premium Pkg//Perf. Tire & Wheel Pkg//Sunroof//Splash Guards//Sirius Sat Radio
Old Oct 1, 2004 | 10:28 PM
WRAH's Avatar
WRAH
Re: Shell V-Power
Hey, I posted almost the same question in the off topic forum! The octane is fine, but I'm wondering about the "additives" (if there are really) damaging the engine. Or is this the same $hit different name.
Old Oct 1, 2004 | 10:39 PM
Re: Shell V-Power
Sorry I didn't see your post. I was wondering the same thing about the additives. They say it has 5 times the minimum detergents but that could also be good as it prevents deposits from starting in the first place (?)
Old Oct 2, 2004 | 08:21 AM
MyGUnit's Avatar
Re: Shell V-Power
same [censored] different name......its all propoganda....every gas station gets their gas from the same factories/refineries. For example, Sunoco may have a huge refinery in which all their tankers get their gas, but at the same time, they sell their gass to BP and Exxon, etc. Its all in brand packaging.
Mitch
2004 G35C 6MT
DG/G
Prem.Aero.Nav
Clear Corners
Old Oct 2, 2004 | 08:52 AM
KingOfJericho's Avatar
Re: Shell V-Power
MyGUnit, you beat me to it.
Gas is gas. Aside from octane differences (87 vs. 93) there is no difference. I am actually surprised noone has mentioned the Sonoco Ultra 94 (I live on the stuff). It truly is the same gas from the same trucks from the same refineries. My father is an oil trader and will tell you the same thing. Brands don't mean a thing in that business, the gas is just gas...
93 = 93 no matter what
87 is garbage and should never grace the tank of a G.
"knock knock"
2004.5 Black on Black 6MT, Aero, Premium, Navi
"You can live in your car but you can't drive your house"
Old Oct 2, 2004 | 11:12 AM
Re: Shell V-Power
Thanks for clearing this up, but my main question is, is it good/better for the engine to run a 93 octane when the manual says 91?
Old Oct 2, 2004 | 11:16 AM
accuview's Avatar
Re: Shell V-Power
What you guys mentioned is only half of the equation. While it is true that all station procure gas from the local refineries, they mix their own additives in the gas giving each brand a slightly different "flavor" (in this case V-Power). How much more useful the additives are is another question.
Coupe CB/Willow/5AT/Prem/Perf Tire & Wheel/Splashguards/Alum Pedals
Old Oct 2, 2004 | 01:23 PM
WolfsterX's Avatar
Re: Shell V-Power
ARH_twilightblue,
In the manual, it does say use Octane 91 or higher. It is purely safe to use a higher octane and most of the time I use Octane 92 from Sunco gas. Lot of luxury and sport cars use higher octane. If you use the lower octane, then the ECU will read differently as mixture of air and fuel. It may or may not damage the ecu sensor, but the performance will be lower. If we say Gas is Gas, then car is car? Toyota Celica is not same as G35 C as oppose to Octane 87 vs Octane 91. Better grade of the fuel, better performance.
<font color=blue>Original G35 Coupe 6MT, Black on Black</font color=blue>
Old Oct 2, 2004 | 04:20 PM
SlayerGTR's Avatar
Re: Shell V-Power
actually.... i used to use gas from QT, dunno if other ppl have it other than where i live, and i noticed after i switched to exxon, my gas milage increased a good 2-3mpg. So in conclusion, gas does matter. Don't alwayz go for the cheapest, few pennies more per gallon can get u good milage.
Old Oct 6, 2004 | 09:51 AM
jwg35c's Avatar
Re: Shell V-Power
Shell V Power is a fancy name for their additive package mostly detergents to keep the internals clean. Most other big oil companies also have their additive packages as well. Some of the smaller (cheaper gas ) companies add very little or nothing to their gas. So much for the additives.
On the other end you have the blending process. Most states mandate oxygenates to be blended into the gas. These consist of ethanol, methanol, MTBE etc. They can effect (lower) gas milage but they help with omissions. Do they effect performance? I don't know. They do lower the BTU rating.
Octane requirements are relative to the elevation you drive at.
If the manual says use 91 octane it probably means at sea level. As you go up in elevation the required octane level drops.
Most of this information was obtained from my brother who is a chemical engineer. He has worked for shell oil company for the past 20 years.
Gas is gas. probably not
Old Oct 6, 2004 | 10:00 AM
XCELR8's Avatar
Re: Shell V-Power
wheres Q45tech... he seems to know everything
2003 BLK/BLK 6MT Injen, clear corners, Eibach sways and springs, tint
My G on a photo shoot. More to come!
Old Oct 6, 2004 | 10:51 AM
nnkfws333's Avatar
Re: Shell V-Power
hum...I highly doubt this. I mean have you ever tried running racetrac gas?
Before I had my SR20DET I had the KA motor inside and it could except 87 octane in my 240sx. I put in some racetrac crap and I started to knock! My engine stumbled and crap. I then went to chevron and put there 87 and my car ran normal.
The same thing went for my SR where I put in speedway 93 octane and I started to knock and barely could hit stock boost. Something is up!
Don't some gas companies put more water or something like that? I mean how does racetrac or speedway sell it for so cheap yet others cant?
S13/SR20 for sale
Old Oct 6, 2004 | 02:01 PM
nate1749's Avatar
Re: Shell V-Power
I'm not a chemical engineer, but I would have to agree that gas does vary by company.
My dad's check engine light went on (99 accord) and when he took it in they told him to put only shell or bp in because a lot of the others were putting too much ethanol in. A guy at work couldn't get his car to start and when he took it in the mechanic asked him if he'd been using citgo (cheap stuff), which he had. The mechanic said he's been replacing 2 fuel injectors (maybe it was a different part) on average a day and they've all been from citgo gas because they were using so many detergents. So if 87 can vary from gas station to gas station, why can't 93?
On the other hand I've also heard from people who've worked at gas stations that the tanker will top off any other tanks with whatever he has left (93 is low and he's only got 87 left so he puts that in there).
Nate
Old Oct 6, 2004 | 02:14 PM
GCoupe35's Avatar
Re: Shell V-Power
Everyone has me confused now.....
What gas company do i use now? I used shell V-power, i didnt like it, felt like it was eating more gas
I use Chevron now i like it, hopefuly staying with it, i aslo have used Diamond Shamrock and thats ok too.
twentyeggs
Sep 11, 2015 03:58 PM
