Drivers Door Wont Lock with FOB
Old Jul 4, 2010 | 03:21 PM
stoofpilot's Avatar
Hi-wheen I lock my G-35, using the KeyFOB, the passengers side locks but the Drivers side does not lock. I can just open the door yet the passengers side will be locked.
Any thoughts as to what might be causing this?
Old Jul 4, 2010 | 07:57 PM
dave's Avatar
It sounds like your door lock actuator needs to be replaced.
Old Jul 4, 2010 | 08:12 PM
Matthew121's Avatar
Same thing happened to mine, I have just been manually locking the door before I exit and using my key to enter. Its a pain in the butt. There is a diy on how to make an aftermarket actuator work. Search for it! HTH
Old Jul 6, 2010 | 02:57 PM
305G35's Avatar
I have an 04 and same problem...you need a new door lock actuator. the stealership will charge $200 plus labor..
i suggest to do a search here...a member custom fabs a replacement for cheap...if you are mechanically inclinded, i say purchase it and DIY.
Old Jul 6, 2010 | 02:59 PM
cdubel01's Avatar
CLUB MODERATOR
^members name is pythonjosh i think...
Old Jul 6, 2010 | 03:05 PM
cdubel01's Avatar
CLUB MODERATOR
here ya go...
https://g35driver.com/forums/souther...cks-fixed.html
Old Jul 6, 2010 | 03:41 PM
vp-g's Avatar
another door lock bites the dust...this part was made by ford? so disapointed in infiniti...
mike730
Jan 12, 2018 04:25 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
whattf
Jul 17, 2015 02:41 PM
