Help!!!
Old Jul 4, 2010 | 05:48 PM
obsidianvq35's Avatar
Help!!!
I have some kind of suspension problem with my 06 coupe. Every time the left side of the car goes over bumps or humps in the road and the right side is flat it makes a sound of like metal hitting...also when you turn on the wheel while not moving, it makes a sounds..is this my tie rods or what? I hope its not like axels or nothing..when you have someone turning the wheel right left right left you can here the sound from the suspension on the driver front and passenger front. I think its just the driver side that is messed up and you can here the noise from the passenger but not sure...any ideas???????
Old Jul 4, 2010 | 05:57 PM
OGKushRob's Avatar
everyone has that problem. there is a service bulletin for it i believe its the endlink and swaybar bushings. you are out of warranty though id assume unless you got one longer than the 4 yrs. 60,000 miles. i was SOL. i hear it all the time too though man. im gonna get new sways though so idc
Old Jul 4, 2010 | 05:59 PM
Do you know what price range I am looking at?
Old Jul 4, 2010 | 06:58 PM
gary c's Avatar
We could post/guess all day long about suspension noises but there's only one way to nail it down, ya gotta get it in the air and check it out. First, you don't want to have Infiniti even look at the problem....$$. I sound like a broken record (old school) every town has an independent brake/alignment shop that knows how to fix suspension parts....find one. Suspension parts all make about the same noise when they're broken/worn out. What I hear more is swaybar endlinks and compression rods, post what you find....knowledge is power!
Gary
Old Jul 7, 2010 | 08:00 PM
So just found out what the problem was and got it corrected...I have the g37s akebono brake set up on my 06 g. The bolts keep getting loose that hold the two caliper halves together. They became loose before but I used locktight to prevent it and apparently that doesn't help either. I used special washers that lock when bolted down in hopes of preventing them from becoming loose again..hopefully this will be and ends to my issues with these calipers becoming loose.
