Lil Help new Coupe Inner Tire wear!
Old Jul 6, 2010 | 06:44 PM
dias724's Avatar
Angry Lil Help new Coupe Inner Tire wear!
Ok so i just got an 06 coupe 57k miles and it is making a horrible huming sound and vibration from the Front end, whenever im over 20mph loudest at 40mph and below. I first thought it was the brake so i took it in and the brakes are good and the guy showed me that my tires had inner uneven wear. So i took it for an alignment today and i see no improvement. Wat could be causing this? I think i might need a front camber kit... but not sure and dont want to spend money not knowing if this will fix my problem. Anyone out there that had this problem and got it fix any tips would be greatly appreciated thx in advance.
I did search googled found similar problems but not an answer.
Old Jul 6, 2010 | 06:54 PM
Swivel's Avatar
Moderator
Lemme guess, you are still running the Bridgestone RE050s? They are loud when they are worn, and at the exact speeds you describe. Solution - replace the tires. Also coupes are notorious for cambering the front tires, even at stock ride height.
Old Jul 7, 2010 | 12:00 AM
GMoney08's Avatar
^+11111. yea its most definitely the tires. I had camber wear when I didn't lower my car yet as well. You can either bear with it to get the most outta your tires or change them to better ones. Many go with falken 452 best bang for the buck!
Old Jul 7, 2010 | 12:04 AM
thescreensavers's Avatar
Mr.202?
If your tires are fooked up, getting the correct alignment wont magically fix them.
Old Jul 7, 2010 | 12:24 AM
walshtj's Avatar
Mine was the same way, except with the noise was vibration. New tires ftw!
Old Jul 7, 2010 | 01:17 AM
nighthawk06's Avatar
Mine got outter wear on 4 tires. Took it to alignment, it helps a bit. Still running on OEM
Old Jul 7, 2010 | 01:35 AM
dias724's Avatar
So should i just get new tires? No camber needed correct?
Old Jul 7, 2010 | 04:38 AM
VictoriousG's Avatar
^ Depending on your drop you might need a camber kit but if your still on oem height then you should just be fine changing the tires.
Old Jul 7, 2010 | 09:34 AM
gary c's Avatar
Since it's the tires making that ROOAAAAAAR getting alignment won't change the noise you're enjoying. Isn't that noise a PIA, you can't turn the tunes up high enough to hide it....solution replace the tires.
Gary
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
JG_G35
Accessories
Feb 25, 2016 01:44 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
jjohns2711
Aug 5, 2015 08:58 AM
