2005 Navigation Screen won't stay up!
Old Aug 10, 2010 | 11:33 AM
Boundries's Avatar
Hi,
My 2005 G35 Coupe's navigation screen goes all the way up then immediately comes back down. The screen stays black and it won't stay up for more than a few seconds.
Any ideas on how to fix this so it stays up and actually turns on???
Thanks in advance for your help, much appreciated
Old Dec 25, 2011 | 08:25 PM
unwise's Avatar
Hey so Ive been having the same problem. Did A LOT of homework on it including researching the infamous TSB on the unit.
No you dont have to spend that much, nor do you have to go out and do a double din replacement (which would run into the 1k range after you get the dual climate control adapter, steering wheel adapter, and the actual unit)
When the screen pops up, the upper limit is determined by the number of revolutions of the motor, not the actual position of the screen. Over time, this limit seems to go out of adjustment.
To "trick" the limit, while the screen is moving up, quickly press down or tap on the screen so it momentarily moves downward then resumes raising as soon as you let go of it. When done correctly, the screen should raise fully; if you hold it too long, the screen will retract.
Now I dont know how long this will fix it, but mines been out of commission for months. Seems to work when its cold not when its hot, and now finally this year not at all. Did the fix mentioned above and ALL GOOD!
Falling in love with my g35 all over again
(NOTE: I'm going to post this in as many locations as possible since its been years since I've been looking for a fix.)
Thanks!
Old Dec 26, 2011 | 01:13 PM
gary c's Avatar
Finally a way to keep it up...^...without Sidenafil & Dapoxetine Tabs!
Gary
Old Mar 22, 2012 | 08:42 PM
ReveryToo's Avatar
It worked, Thank you so much !
Old Jul 24, 2013 | 07:43 AM
n15m0's Avatar
sorry to resurrect an old topic. having the same problem, tried the fix above. can get it to stay up but screen still remains blank... :S Any ideas?
Plur
Interior
May 22, 2019 04:35 PM
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
wuppiedog
Aug 7, 2015 11:16 AM
Jussaku
Interior
Jul 29, 2015 04:13 PM
Thaaa_king
Jul 18, 2015 05:56 PM
